"Building Dataset Elements and Building Display Accelerators are cached by AECOSim Building Designer to speed up operation of any files containing Dynamic Views." Excerpt from Wiki entry.
Q1: Is it worth purging the BDA's if you are not using DV's? .We have to use DEM. The problem is that the files are stored offsite (Yes, we have PW and cahcning servers).
Q2: Are the Display Accelerators the same as what TFHRYDRATE.EXE used to do? If so, this would predate DV's
Just to add... Building Dataset Elements are part of the process that automatically scans each DGN file when opened to insure that the levels used by your Family+Part system are available for DVs. If you are not using DVs in any fashion whatsoever, then you probably won't need this. And in that case you can set BB_DVDATASETELEMENTS = 0 to prevent those levels being written to each DGN. Should you ever venture into DV-land, however, you will definitely need to reset it to =1 in order for Part resymbolization to work. More information is available in the Help under "Configuration Notes" and in our Wikis - communities.bentley.com/.../compress-options-can-affect-drawing-view-performance.aspx
communities.bentley.com/.../8252.aspx
As Travis mentioned, Display Accelerators is what we formerly referred to as TFHydrate, originally introduced in Bentley Architecture V8i, and helps to increase DV performance at the expense of a slight increase in file size. It's essentially generating Parasolid bodies within each Building element which translates to faster processing vs. the older "recipe" method. The second post by Pradnya in this older thread explains it well:
communities.bentley.com/.../158639.aspx
