ProjectWise integration with dataset_materials.dgnlib
We're finding changes to the materials library are not being updated to ProjectWise, and instead only the local C: drive copy of dataset_materials.dgnlib gets updated.
When we make changes to the materials library, from a standard file, we access it via the menus: Settings>Rendering>Materials. We then make our changes, then "Copy to Library" and "Remove Local Copy" for any materials we've amended.
This process seems to update the dataset_materials.dgnlib on the local C: drive but does not check-in the change back to ProjectWise. As a consequence any change only affects the local machine not all users.
We are therefore having to manually copy the local file back to ProjectWise, to make site wide changes.
Please could someone confirm whether this is an error in ProjectWise integration or if there is another reason why our workflow is not sending the changes back to ProjectWise.
