In building designer model we have linked our section/elevation/plan/detail call-outs to PDF drawings.
So when you click on a call-out it opens the PDF.
However, when we export to IFC there are no callouts that open PDFs.
Does anybody know why this might be the case?
I.e. Does the building designer file need to be collated or packaged in some way prior to exporting to IFC format?
Any help much appreciated.
So are the targets of the links individual pages or bookmarks within the PDF binder?
Which elements in the DGN are you linking to the PDF targets?
Marc
IFC is not designed to support proprietary DGN features like our callout links.
You may be able to add an approriate internet URL accessing PDF (if the PDF can be accessed via a URL) as a value of an appropriate property, if there is one.
