"Fear of the Refresh Button"I'm finding on larger projects, where each floor breaks into multiple sheets, that refreshing auto annotations can/will undo much more work than it updates.Workflow, as standard, is create ductwork/piping/plumbing, then dynamic view, then drawing model and sheets. (Presently the only auto annos employed in drawing-model are Top, Bottom, Centerline, and Invert-Level start/stop elevations). After the drawing model is created, It's necessary to do some custodial work for presentation and re-arrange auto-annos, delete unnecessary auto-annos, and add DG anno cells. Now if a small group of components change elevation in the design model (e.g. a 15' run of 8x6 duct lowered 2" toward the floor), refresh auto annotations will reflect that change in the drawing model, but will also undo 60-70% of the custodial work throughout the whole floor. Depending on the size of the floor, redoing the custodial stuff can be extremely time consuming.The items that are undone are all the deleted auto-annos, some of the re-arranged auto-annos, and the DG anno cells that were placed that indicate vertical components (like duct that passes thru to the floor above or below). The later just disappear, the former reappear. (Oddly, only 40% of the re-arranged items are reset to default locations, the rest stay where I put them).The only workaround I've discovered applies only to the DG anno cells mentioned above. If I drop them once then they will survive a refresh, but the drop forces them to lose their association with the component....and here's the request:1. Please allow the Drawing Composition Task "Refresh Automatic Annotations" to present a tool-settings option: "Refresh Per Selection Set".This would actually eliminate two issues I've experienced with "Refresh": ...As noted above, and the "Visibility Calculator took longer than expected!" thingy.Thanks,Jeff
Cutodial work being overwritten....
communities.bentley.com/.../81233.aspx
communities.bentley.com/.../68191.aspx
communities.bentley.com/.../192412.aspx
communities.bentley.com/.../91409.aspx
.... I think that the moved annotations only retain their 'custodial' manipulations when they are generated with rules then manipulated.
It would be good if Bentley would address how to 'persist' custodial work more effectively/easily, soon.
The more I think about it, the more I see that "refresh per Selection Set" is The way. Very logical. It's similar to changing properties; If you need to "change level" of a single line amongst 10,000, you can select that single line and do it without affecting the other lines. Why is there a Selection Window? Why is there a Fence??
Well here's my work-around (as copied from my personal notes):
Select and Group everything desired to be untouched by "refresh". "Locking" the Selected will not work. Perform the refresh. As well as the area that needed the Refresh, everything will be regenerated to default (as defined by drawing Rules). The grouped items will remain as they were (unaffected), and you'll now have tons of duplicates that need to be deleted; Just don't use a crossing window to select stuff to delete, cause you don't want to delete the big "group". Also be sure to not delete the new stuff that even made you do the refresh. Now, after the delete step, ungroup the big "group", and you'll have effected a localized refresh with annos retaining associations.
Again, ...must see function for localized refresh: "Refresh Per Selection Set".
I placed an SR but better if more people send an SR. My last ones didn't get answered at all.....
Your request has been received and a Technical Support Analyst will contact you as soon as possible. Please note your Service Request number 7000108723
My SR is mentioning that all DG annotations disappear after the element got modified in the model.
Wolfgang
Wolfgang, I've picked up your SR as well since it seems to be part of the same issue.
Ustn since 1988SS4 - i7-3.45Ghz-16 Gb-250/1Tb/1Tb-Win8.1-64bEric D. MilbergerArchitect + Master Planner + BIMSenior Master Planner NASA - Marshall Space Flight CenterThe Milberger Architectural Group, llc
