We have a serious problem with the IFC export process. I've attached screen grabs from AECOsim and Solebri to demonstrate as well as the .dgn file and the .ifc.
In AECOsim I've input data into the ID|Number field of a column: "S11".
When I export this and open it in Solebri, the same column now reads ID|Number: "S12".In fact all four columns in the IFC, using that steel section read: "S12" even though in AECOsim they were tagged ID|Number: "S11", "S12", "S13", "S14".We cannot use data fields if we are not 100% confident the information can be exported reliably. Is anyone able to advise why this might be failing?
MarkABD SS4 v08.11.09.627 ANZ Dataset
And here's the ifc...
I would strongly encourage you to file a Service Request on that one.
If you want we can make an internal competition about who filed the most SR's on ifc related bugs :-)
Service Request already lodged.
I laughed at your competition idea - until I remebered how serious the problems are!
Hello Mark,
Regarding SR#7000103137. Our development group have identified this as a defect and we are working on a resolution.
Regards, Sunil
