I'm using AECOsim Building Designer SS4. I want labels to be placed on section beams through rules. It seems the only way to do this is to make the beam a line. Is it possible to display the full graphic rep of the beam with label?
In order for a label to be applied, the rule must have either single or double line toggled on.
Steve, is there an SR on removing this limitation? We always show the full graphics and would like to have automatic labels for steel members.
create a new Rule with Rule Type for Top/Side Annotation not for Top/Side Resymb.
sorry but I've problems to attach an Image but you'll see it when creating a new Rule
Answer Verified By: Eduardo Cortes
Good call, Karsten! I always forget about the annotation rule templates.
