When trying to open a model or a file in AECOsim Building Designer integrated with Project Wise, the program closes unexpectedly. However opening the same file or model outside of Project Wise the file and model opens with no issues. On behalf of Elizabeth Lee.
This could be a number of different things. Have you tried opening the file with just MicroStation in ProjectWise? If it opens with MicroStation, then it is probably something wrong with the PW Application for ABD or the managed workspace. Is the ABD workspace managed or unmanaged?
-travis
this is a managed workspace. The file open initially with no problem. It is when I try to move to a different model within the file or create a new one that I am kicked out. There isn't a problem in Microstation and this in only on one computer.
