Isolate, or is it Displayset>Set?
Attempting to follow AskInga's 'Hide Elements by using options in the right click menus'
http://communities.bentley.com/communities/other_communities/askinga/w/askinga/5926.aspx
First, has Display Set been re-named Isolate? Did anyone tell us? - it's not updated in Help.
Second, having done R click>Select All>R click>Isolate, the Ref'd-in drawing disappears as it should, but the Linear Forms and Free Forms don't - are they immune to Isolate?
  • Hi Tom,
    Isolate and Isolate Clear are context menu items that use the Displayset function.
    Isolate runs 'displayset set selection'
    Isolate Clear runs 'Displayset clear'
    When you pick Isolate, note that [Displayset] is added to the view window's title bar.
    You can use View Attributes > Displayset to toggle the isolation on/off without clearing it.
    It should work with any selected elements, if not please post a sample file.
    Marc
  • Hi Tom,
    Unknown said:
    while 'Treat Attachment as Element for Manipulation' was checked in References dialog
    the reference is treated as a single element so display set will not be able to access individual elements. (I think the idea of this option being to reduce the number of clicks needed when moving, mirroring, etc a reference. These days people tend to have their references in the right place rather than randomly drawn where the first mouse click happened to be so less need to move them around.)
    Unknown said:
    If not, why call it 2 opaquely different (and undocumented) things, just because it's a 1-click shortening of a 2-click procedure?
    • Isolate is a specific process (or workflow)
    • Displayset is the tool that enables it.
    • The Isolate menu option is an ease of use overlay.
    • Displayset isn't a legacy tool.
    Also Displayset's additional features, Add and Remove for instance, might sound a bit odd if Displayset was renamed Isolate.
    Thank you for pointing out that Isolate is undocumented, defect 86647 has been filed.
    BTW, note that Isolate is context sensitive and only appears when elements are selected.
    Marc
  • I discover that a Ref doesn't get included in a super-easy Ctrl +A (or R click>Select All); is selectable only by e.g. ElemSelect>Block.
    That's a drag but only a small one, because after Ctrl + A, Ref(s) can be added to the selection with one click provided 'Treat Attachment as Element for Manipulation' is checked.
    Except that's no use, because after Displayset>Set (or Isolate) the Ref's linework disappears, leaving only the Ref's boundary visible.
    Is there any gd reason for the latter?
    I do realise that "the reference is treated as a single element so display set will not be able to access individual elements".
  • I think the linework dissappearing in the Ref with TAAEFM set could be a bug but it may actually be WAD. I don't like having that set on a Ref because when you do Level Off can't be used to hide a particular Level in that Ref.
    With TAAEFM the Ref is treated like a block/cell, and only the Level from the "cell header" (Level setting of the Ref) is shown or hidden, not the levels of the actual reference.
    In the same logic, if you do an Isolate on that Ref only the elements on the level of the cell header are shown and that probably means all the linework will dissappear. It's probably logical, but not very useful.
  • Is this suitable for a SR? I would like someone to look at these 2 questions:
    a) why the confusing dual terminology, introducing Acad-alike 'Isolate' meaning same as 'Displayset>Set'.
    I suggest the opposite - get rid of Isolate, forget defect 86647 - why shouldn't the Ctrl+RMB command read literally 'Displayset>Set' instead of 'Isolate'?
    b) why shouldn't selecting a ref for inclusion in a Displayset (to remain visible as-is) count as a Manipulation as defined by the setting 'Treat Attachment as an Element for Manipulation'? Why, with TAAAEFM set, should the ref's linework disappear after Displayset>Set, leaving only its boundary visible? I understand that technically with TAAEFM set, only the ref's boundary gets selected, not its contents, but still ...
    Can I file a SR that simply gives a link to this thread, instead of writing it all out again?
  • Unknown said:
    people tend to have their references in the right place ... so less need to move them around
    Unknown said:
    I don't like having that set on a Ref because ...
    Quite agree - I only set it when I want to reposition the ref e.g. a 2D plan ref to exactly the height where its line ends can be snapped to draw the base line of a BD Form. Other times I want the 2D plan ref hovering well above the solids so its linework doesn't get in the way but is till useful in Top view. After moving the ref, unset TAAEFM again.
Reply
