ABD ss4 difference between section and elevation in Create Building views
A section is a cut through the 3d-model.
An elevation is different. It shows the face of something, or perhaps more correct, the projection of an object/s to a plane.
So I looked forward to use PLACE ELEVATION CALLOUT > INTERIOR ELEVATION.  Cool tool.
But my testing suggests it produces SECTIONS, not elevations.
It does exclude a wc chair - but not other geometry at the location of the callout that don't reach to the wall at the direction of the callout.
I can still place a separate elevation-callout very close to the wall. But that nukes the beauty of placing all four elevation of a room in one go.
Just me ?
Parents Reply
  • I think the thought process of what an elevation or section are need to change a bit as what we use has changed
    • I see the same of a section looking at the front of the building and clip, hide or hatch over the footing if shown.  sometime even make then dashed so you see more that a typical elevation but the same as the was some have drafted for years.
    • O don't know if we can only show the interior perimeter of the section.  I have seen plenty that show the wall section also.  It can become a section elevation at the same time doing more in a construction document.  Interior pattern of walls can do just as well as the thick lines.
    • I don't know if you need to do that but rather change the thought process.
    Ustn since 1988
    SS4 - i7-3.45Ghz-16 Gb-250/1Tb/1Tb-Win8.1-64b
    Eric D. Milberger
    Architect + Master Planner + BIM
    Senior  Master Planner NASA - Marshall Space Flight Center
    The Milberger Architectural Group, llc
