I have a lot of existing Building Views (without Steps) which are used in Drawing Models and Sheet Models.
Now I Need to add a Step in some of my existing Building Views.
Like this example.
When I create new Building View I can add a Step, but I don't know how to add it in an existing BV.
Help would be very appreciated!
Thanks.
Christian
WIN7-64bit (German)ProjectWise SS4 08.11.11.574 EnglishAECOsim SS4 08.11.09.593 EnglishDataset NM 08.11.09.579 customized
Travis,
Thank's for your help. I tried it and it worked.
But it's a little bit cumbersome.
So my wish would be to add the step at the same way as it is possible on a Clip Volume,
Right-click->Create Step.
By the way, what is the key-in for Create Step?
I agree. Typically to modify the clip, you would only need to toggle ON the 'Show' column of the saved view to present the saved view boundary. Ideally, you would be able to use 'Create Step' on that boundary. I would file a service ticket to generate a Change Request to be able do that. Users filing Change Requests hold more importance than me filing it as a Bentley colleague.
Create Step Keyin = sectionclip createstep
-travis
Answer Verified By: Christian Mittermeier
I have filed an SR for it.
7000129156
Hi Chris,
I've taken your SR and will link it to Enhancement 86193 for adding a Step after the Callout has been placed.
