View Mis-alignment DEM
Hi All
Apologies if this has cropped up elsewhere and once again if it's a very simple problem but...
We are using AECOsim Building Designer V8i (SELECT Series 3) through (Projectwise V8i SELECT Series 4) and are producing our architectural drawings via extraction from Master Model Files.
We have been using the standard 'cut location' tools in the DEM to pretty good effect, however we are now at a stage where we need our extractions to be more focused and isolated than the infinite plane cuts produced from the above.
Therefore we have decided to use saved views as the basis for our extraction - again within the DEM. All views look correct and display properly, except for following extraction a blank file is created. Upon entering the 'building group model' it appears that the  position of the saved view is mis-aligned i.e on a different plane?
Can anyone help?
Parents Reply Children
