How to show grid in section building automaticlly ? os shall I put manually
AECOsim-Dynamic View
As long as you've created your Grid System and generated the applicable Grid Models, enabling the Show Grid System option in your Drawing Model should be all that's needed for the grid to display. Assuming that there is a grid for that elevation, of course.
Answer Verified By: dweib
Thank you Steve , I have another question can I create grid without floor manager ?
??? Are we saying that the grids in section will only show up in the drawing model and not in the 3d model?
No i need the grid in both of them , but is it necessary to build a floor selector ?
