Hello everybody
I have project with multiple building, each building has differnet grid , how ican create grid for each one ?
urgent issue please
create each as a separate project
then reference into a singular model
Ustn since 1988SS4 - i7-3.45Ghz-16 Gb-250/1Tb/1Tb-Win8.1-64bEric D. MilbergerArchitect + Master Planner + BIMSenior Master Planner NASA - Marshall Space Flight CenterThe Milberger Architectural Group, llc
do you mean that i must have floor master "BB-floor master " file for each buidling ?
yes you do
It depends on how you to that also. If each building is the same project then only one BB-floor Master.
If each is a different project then yes one floor master for each.
Then also you can point all projects to the same BB_Floor_Master in your settings under Workspace preferences (all project) on within your Project user.ucf file for that project only (make sure to lock the variable)
each building is the same project , but each buidling has its own grid , what should i do ,
if i make floor master file for each building , is this will affect another sitting ?
In a bb_floormaster file you can have multiple buildings each with its own set of floors and reference planes.
In this case the naming scheme floors and reference planes would probably reflect the buildings containing them, e.g B1_Floor_00, B2_Floor_01, etc.
When you create a grid where the bb_floormaster has multiple buildings you will be prompted to select the building to which the grid will be associated so you have to choose B1 or B2 so are unable to use the other building's floors and reference planes.
One way to get around this current limitation would be to have a single building containing all of the floors and reference planes named as previously, this would allow you to created grids based on selecting the appropriate floors. Not ideal but one possible workaround. However this is not the best method for IFC output where the building is part of the organisational structure of the IFC (which is one of the reasons for the changes to the Floor Manager tree structure). You would also have a lot of floors listed in the floor selector.
Creating separate projects for each building is probably a better route to follow. As well as allowing you to create and store the grids for each building separately, the separation will result in a less busy list when using the floor selector.
Please can you post an example schematic of the project or describe its arrangement. We may then be able to offer some more specific advice.
Marc
