I cant see the cut pattern in section of concrete , what is the possibilty?
Could be something as easy as scale. When I make patterns I have a typical element that I work with a 1' cube that I see elevation, rendered iso and section. This way I can check that it will work
Ustn since 1988SS4 - i7-3.45Ghz-16 Gb-250/1Tb/1Tb-Win8.1-64bEric D. MilbergerArchitect + Master Planner + BIMSenior Master Planner NASA - Marshall Space Flight CenterThe Milberger Architectural Group, llc
Play with your pattern scale. I think that may be it.
Guys as I told you before this important , I need solution As soon As possible .
Again WHich is the file that contol this pattern ,?
Nadeem,
I have replied you from the SR. Please answer so we can have a look.
In the 3D model with the cut applied, if you rotate the view away from front on can you see the pattern then? I having a problem where my cut pattern becomes hidden when looking at it square on. It appears if I'm in an isometric or turn hidden edges on for the cut symbology. It happens on my Win8.1 laptop but seems ok on my Win7 work PC.
It is a Dataset issue.
Could you be more specific on what was broken in what fiie?
