I cant see the cut pattern in section of concrete , what is the possibilty?
Could be something as easy as scale. When I make patterns I have a typical element that I work with a 1' cube that I see elevation, rendered iso and section. This way I can check that it will work
Ustn since 1988SS4 - i7-3.45Ghz-16 Gb-250/1Tb/1Tb-Win8.1-64bEric D. MilbergerArchitect + Master Planner + BIMSenior Master Planner NASA - Marshall Space Flight CenterThe Milberger Architectural Group, llc
Play with your pattern scale. I think that may be it.
I tried all of your suggestion nothing works , this problem is on work workspace not on my labtop , I think the problem is on workspace , Any other suggestion ?
You may try seeing if pattern cell you are using is being found on your laptop.
If you select on cell in your parts library it will indicate that it is not found.
When cell in part library can't be found it will not distinguish itself by turning red or some
other indicator. The only way to tell is to pick cell.
HTH's
Tom
I tried your file on my out of box dataset and it worked fine. I think Tom is headed in the right direction.
Travis
