Aeco vs Revit or Archicad
First of all i must say that i am an Autodesk user.
I use Autocad, Civil 3d, Revit Architecture and in the past autocad architecture. I,m from Greece where its difficult to find microstation users.
For education and skill improvement i start watching the training videos of microstation and open roads technology , and in many cases i like very much some features they have.
So last days i watched some videos of Aecosim building designer.
I have also download a 30 day trial today.
But after watching the first videos, not fascinated at all and i want to ask a few things to decide if its worth to continue training.
At first i must say, that what i liked in bentley ,is that it has the same platform for the most of its products. So i believe that if you make a model with power in roads you can open it with Aeco and you can model some building elements it . And then continue with power in roads, with road design.
I open a dgn file which i made with the live training that i get  a month ago with Power in roads, and i open it with aeco and of course i cant edit it but i can model some things save the file and then continue with power in roads. Is that true? I dont know if this could be done with the previous version of power in roads which was project based like the old Autodesk land desktop.
In Autodesk side you need object enables ,witch sometimes don't work perfect between Autocad and its vertical, but you cannot doing this with revit which you should export it in order only to see in in e.g. civil ed and not as you see it in revit.( no materials and other visual effects.
But what i see in the first video of Aeco is that instead of open roads technology,You must build a project, in which every floor is  a different file and in the end all floors attached to a separate file to built the whole model.  Its like autodesk architecture. But this workflow has some serious disadvantages.
You cannot make edits in sections and levels of the whole building. E.G. you cannot align windows of different floors in an building elevation view.
Its not as dynamic is a project in a single file.
I think this way is an old way and this is why autodesk buy revit which is similar to archicad, with many differences of course but with the same philosophy.
But as i said i don't know Aeco and maybe i am wrong.
So i want to ask. Is it possible in Aeco to built the whole building in a single file?
I saw that with floor selector i can built easy multiple floor in a single file but is there an option to make clipped views in a  range of every floor?
Is it possible to work in a single file?
And another question.
When i start Aeco it says that there was no interoperability with previous versions?
So a model make witch made with Aeco SS5 won't be opened with Aeco SS4 or it will be opened and it won't be edited?
  • Ok. As i said i'm not very familiar with bentley products but for the general concept i think i will prefer revit over Aecosim.
    What i ' m really exited in the open road technology which seems very promising.
    This is the reason i'm starting trying bentleys products and i gave a look in AECO sim.
    The multiview display function is that that i most missing from autocad. I think microstation has this technology from the first releases. I think it will be probably a huge step  to create as many views as you want per model and organised them in a project viewer. it will extend very much the program capabilities, such as the things i'm asking above.
    Again thank you for your time.
  • Eric said that i can work with a single file. But i don't understand how then i will create floor plan views for each separate floor.
    There are two obvious ways,
    1- Create a Building Views, plan and/or sections,  and place them as separate Models in same file as your 3d. Then while in your 3d-model you can apply them in any of ABDs 8 View Windows. You can then edit the geometry in 3d or in the 2d fully resymbolized views. (View Attributes>VIEW Setup) or use the Markers and MIni toolbars.
    2- use 'clip volumes'
    and some others, like putting thins on separate levels/layers.
    regards / Thomas Voghera
  • "Create a Building Views, plan and/or sections,  and place them as separate Models in same file as your 3d. Then while in your 3d-model you can apply them in any of ABDs 8 View Windows. You can then edit the geometry in 3d or in the 2d fully resymbolized views. (View Attributes>VIEW Setup) or use the Markers and MIni toolbars. "
    How to do that? is there any workflow? As i said i m very new to miscrostation
    Sure. But if you will probably want to work in one environment at some point. And if you need to reach across civils, plant and buildings...
    Err.. I think this is already possible with the Project Explorer in Mstn.
    [/quote]
    But you said to me that   " You can have 8 views per model "
    Now you said that i can create as many views i want in a model?
    You mean that i can create as many views as i want but not see more than 8 simultaneity?
