Back into elementary difficulties:
Why won't this work? - pic - Cut (Split, retain both) all the roof Solids (Free Forms) by the green Curve. Either refuses, or removes the cut-off part of ea Solid.
dgn accompanying.
fostertom,
Did you get a chance to look at this using Forms? Let me know if you have any questions.
travis
Yes, going all round the subject, just made systematic notes on LinearForms behavior as in
communities.bentley.com/.../285660.aspx ;
at this moment baffled by FreeForms as in
communities.bentley.com/.../285679.aspx .
Your comments introduced me to the unsuspected world of Feature Cuts. You mentioned Stretch and I made systematic notes on how that would modify LinearForms; and lately I've realised that Select Handles do similar.
Questions? wd appreciate any light you cd throw on the above 2 links.
