Hi, I created a space labels that were not on the list of MRU_Lookups.xml.
I do not want to appear in the list of labels.
How I can delete labels that are not in MRU_Lookups.xml ?.
See pdf.
Joaquin
There are actually two MRU_Lookup files; one delivered with each dataset under the \datagroupsystem folder, and another that is generated based on user input under the local \prefs folder.
If these space types are not in either of those files, they could also be in the EnumLookups_Architectural.xml file under the \datagroupsystem folder.
Hi Steve, thanks for your help.
I found the file in local ...\ prefs folder. Here it is the list labels of the space and the data list of the stair that I wrote manually at the time of placing these items.
But in the case of doors and windows, I not see that the data list of the height and width to be saved there, but yes other data of the catalog of doors and windows that I wrote manually at the time of placing these items.
I wrote much data the width the door, but now I not need this data in the list.
I need delete some data the list the width the doors.
Is it possible to find a file where it is saved?.
Thank you.
Joaquín
You're welcome!
That is interesting... I never noticed (or even looked) that those DG values were not stored in the MRULookup file. Instead, it looks as though they're stored in the atfprefs.rsc file, also in the /prefs folder. But since this is a binary file, renaming it would likely be your best bet. Note that you will lose anything else that was written to this file, though I'm not really sure what that might be.
Answer Verified By: Joaquin
I found the file of name atfpresf.rsc.
The problem is that I can not be able to see the exact contents (binary file).
If it were an XML would be better.
Thank you for your help.
Regards.
You're welcome! I'm not sure of the technical reasons why certain values are written to the resource file instead of the MRULookup, but at least there's a simple way to "reset" it! :)
