Clip Volume Plan/ Structural Rule problem
hi,
when creating a sections using the clip volume tool I’m getting good results. Plans seem to come out with correct cut patterns, line weights ect but when I add a structural rule to columns on a GA my cut pattern disappears when the rule is added. if I turn the rule off I get my cut pattern back. Anyone can suggest a way to get both to show up?
thanks
  • Would you mind identifying the Bentley product and product version you are using? We can then make sure it gets to the community forum that it is most applicable to. TIA
    Sent: ‎Friday‎, ‎May‎ ‎16‎, ‎2014 ‎7‎:‎17‎ ‎AM
    To: BeCommunitiesFeedback@communities.bentley.com
    View and reply online
    Replying to this email posts your reply in the thread.
    ________________________________
    hi,
    thanks
  • I'm using Structural Building Designer V8i SELECTseries 4
