Is there a way to set the base units of the quantify tool to metric?
All the time I need to check it because it show metric, but when you save your data is in imperial units!
AECOsim 08.11.09.376
abddataset_gb081109386en
Do you have an example?
Hi Steve,
Sorry taking so long, but I talked to Brasil support people and they told me it is a known issue.
When i use the quantify tool, even it shows Metric in Base Unit, when you click Set Units it shows Imperial.
Just changed to SS5 and it is the same.
Are you trying this with the Ss5 GB dataset? I just tried a really simple case but it seemed to work OK.
