Hi, Is there a way of changing the default wall connection (at placement time) as in the attached screen capture? I would like the default to be L connection.
TIA
Bentley, can you please help to answer this question?
In the Place Wall toolbox tick the Auto Connect option. This will mitre walls of the same type.
You also have the option to Close where your wall will "rubber band" until you place the last point.
Marc
I know the walls will mitre using L bisector, I want them to mitre using L parallel by default....is this possible?
Sorry, I appear to have misunderstood.
So you would like the default to be as shown in your screenshot, not to mitre?
Yes, we would like the default connection to be as in my screen capture (i.e. L Parallel)
