I recently installed V08.11.09.747.
The intersection snap is not working, not in the multi-snap or in the stand-alone snap.
Sincerely,
Wim
Are you sure there is an intersection between the elements? It seems to work just fine on lines in the same plane so it can't just generally be broken. What are you trying it on and with what command?
Koert
yes we are sure but we are talking about tridimennsional elements like walls, forms, slabs, columns. Is a bug very annoing.
Is there anyone at Bentley that controls the basic tools before the release of a new version of the program?
Leonardo
Koert,
It works on everything, except on Triforma and Architectural forms.
ah well then ...... is not that bad .... in fact still no response from Bentley
The same for the short cut "ALT-LMB", does not work on Triforma and Architectural forms.
