unifier Level
   I am using NM dataset , if you used unification in section and F&R we will see all of the items on the same level (the level of unifier wall ) not each item has it's level
example :  column beam and slab and each of the has the individual level ,in the section you will find all of them on the same level .  any suggession ?
