Regarding grid we are getting two grid balloons are overlapping each other,And Grid text and dimension text appear same height, whereas we need Grid text – 3.5 and dimension text-2.5.
Hi, sorry, yes you are correct, we do not have a fix for that at present, Enhancement 74789 was filed concerning operation of the Grid Lines settings. We are working on a number of enhancements to the grid systems tool targeted for a future version of ABD.
Marc
Answer Verified By: Steve Cocchi
thank you for your calcification ,but what is the solution now , how I can work around this problem ?
what is your suggestion
and if your answer is officially from Bentley , because I raised SR for this issue and another issue usually there is no reply form their side
The current Grid Systems tool is the first stage of planned replacement/improvements to the Grid tool previously provided in Bentley Architecture and earlier versions of ABD. It is recognised that there are limitations to the current version of the tool and a number of Defects and Enhancement requests have been logged for further development.
The Grid Systems tool is designed to work with Dynamic views, and very importantly in the wider context of our product range, with our Structural tools to allow grids to be used across a range of our Building applications. Neither of these were possible with the old grid tool.
We do not have workarounds for the current limitations of the Grid Systems tool other than conventional manual methods that do not use the Grid Systems tool. For instance, modifying the grid models that are generated by the Create/Update Grid option is not a workaround as these models are an output of the underlying schema, any changes made to them would be overwritten by a subsequent update and also would not show up in Building Views when the 'Show Grid Systems' box is ticked.
Please post the related SR number here.
