Hi
im using AECOsim SS5 08.11.09.747 with ProjectWise SS4 08.11.11.574
I have setup a managed workspace on projectwise but im having problems with the doors/windows tools under the architectural design tab. when you click on one of the buttons to load AECOsim just hangs, like it cannot find the file it needs to run.
I used the ProjectWise administrator tool to import the workspace to start with and the config blocks. I have now modified the workspace to pick up my project specific information sitting on top of the GB dataset.
what variable controls where the door and window tools get loaded from? I haven't set the TFDIR variable as this is set at the application level and points to the GB dataset on ProjectWise. I did try adding this config to my project config file and these windows and doors tools worked fine but I did receive a lot of errors when loading. when TFDIR is not set I receive no errors when loading but the tools don't work.
not sure what variable to set or which folder to look into to make sure everything is copied across.
Peter07760886306
Peter, is it only the Door and Window tools that are behaving like this? What about other cell based components such as Curtain Walls, Plumbing Fixtures or Shelving?
Also, are there any errors in the Message Center and/or does the DataGroup Validator show any errors?
