Hey all, I need some serious help.
I am new to the Bentley infrastructure and having some major problems.
I have models supplied by our process engineers and our structural engineers. I have been shown how to create a project and reference these models.
I navigate with most of the references turned off.
Navigating the model takes an inordinate amount of time.
I get 20-40 crash/error report popups per day?
Where to I start to gain my sanity back?
Eric
a faster strategy than one at a time is to load half and see if it crashes. Then half of that etc.
regards / Thomas Voghera
I have also had more crashes in ss3 and ss4 than in earlier versions.
Many with plotting.
And opening a file takes much longer time now that earlier versions.
And it is ABD and TF forms, not with plain geometry.
Thanks for the answers guys.
So 32-bit limits apply to RAM use (I should have seen the (x86) install - Doh)
I have my paging file on an SSD (I would prefer to not use one though windows seems to need one..) though this shouldn't have much impact on a 32-bit package...
@Marc, I was going to post that compression settings aren't relvant, until I read the posts and have made changes accordingly.
It appears I need to make the time to investigate which references are causing these issues, time that I don't really have, yet can't afford not to spend!! Oh the joys of OPS.
There is a known memory lead that happens with plotting and dwg creation when the files or file processing is very large. the processes I stated above helped me.
Ustn since 1988SS4 - i7-3.45Ghz-16 Gb-250/1Tb/1Tb-Win8.1-64bEric D. MilbergerArchitect + Master Planner + BIMSenior Master Planner NASA - Marshall Space Flight CenterThe Milberger Architectural Group, llc
The paging file shoudl not be on the SSD as the Read/Write will wear that device out more quickly. I moved mine and gave it a very high number. If it needs it it will use it - if it doesn't it won't
