Is this expected behaviour?
When I turn on Boundary Display in some views I get
I have 30 or so references, all of which have display turned off.
What can I do to stop these from displaying?
The two taller ones with the solid corners look like Clip Volumes/Planes, but the others do look like typical reference attachment boundaries. But that is the purpose of the Boundary Display attribute - to display both clip volumes and reference boundaries.
Hey Steve, thanks for your response.
I am getting mixed results....
This only happens with some files some times. Generally the boundaries only show when the reference is set to Display?
So can I assume that this is a bug or have I accidentally flicked the wrong switch?
Good question.... I do only see reference boundaries when that attachment's Display is toggled on.
Do you have a reproducible case where you're seeing otherwise?
Unfortunately not....
It happens sometimes with my first (a.k.a. only) project...
Unfortunately I am completely new to AECOsim and am using consultants files, some of which are problematic...
Generally a restart removes the issue, though sometimes not...
Hmmm... if a restart can resolve the issue, I now wonder if it's some type of graphics issue. Or, you could also try renaming your existing \prefs folder and allow ABD to generate a new set of preference files.
