I conncected two walls with L connection , anybody have idea why it detected as clash in clash detection
see attachment
Assuming that's a default mitered connection and not s true overlap, there shouldn't be a clash. Does your Rules tab have the default suppression rules checked similar to the attached image?
yes it is similar , and still I got clash
OK, they do appear to be identical.
I would first suggest using the Connect Forms As L (Bisector) tool on those two walls, just to be sure that the joint does not contain any overlapping geometry. Based on the image alone that's the only thing I can think of.
i used that one to solve the problem but it is not the default one , how I can make it default
But that is not a viable solution as a mitered cut is proper for unification and centerlines.
Ustn since 1988SS4 - i7-3.45Ghz-16 Gb-250/1Tb/1Tb-Win8.1-64bEric D. MilbergerArchitect + Master Planner + BIMSenior Master Planner NASA - Marshall Space Flight CenterThe Milberger Architectural Group, llc
I don't understand.... the two walls in the image already have a Bisector connection. By using the Connect tool after the fact, you are just insuring that the connection is valid. What I am not sure of though, is why the connection would not already been in this state.
because of the comment earlier I am wanting to make sure we are not having to replace the miter connection with the L connections as they do different things when rendered
Correct, Bisector refers specifically to a mitered connection while Parallel is a typical "L" connection.
Though I'm still unsure why the original Bisector connection was not valid - it seems that was the cause of the clash, as though there was a true overlap and not purely coincident faces (which the suppression rules would cover).
