I'm trying to do something similar to the 3d door swing which comes with the delivered paz's. I don't seem to be able to hold my mouth right in order to re-create the effect. I know it must have something to do with the directional or planar constraint to a Path2d as well as the positioner setting for the component. But this one boggles me. Can anyone tell me how Bentley did it? I'm attaching the portion of a ABD door which has the 3D opening angle constraint as an example of what I'm trying to do.
Dan, Thanks for your time. I thought it might be a planar problem. I know Auto Components were planer, and I tried creating the door leaf every which way but loose. Well, actually I tried it Loose too - I created a path on a tapered extrusion and used that path to create a door to see if off-axis plane would work. I considered playing with Rigid Component but hadn't gotten that far. I'll try to use the Rigid Component method, but I'll go ahead and mark this one answered. Once again, thanks for your and Steve time.
