I am a new user of Energy Simulator. I would like to ask for help with regards to roofs. I have a building where there are internal ceilings for the individual rooms.
Above the internal ceilings there is an exposed pitched roof.
When I produce the 3D model and add the shape of the roof, the software extends the room walls and room volume to match the shape of the pitched roof assuming that the rooms have vaulted ceilings and not rooms with internal ceilings.
Do I not add the shape of the roof to my model and assume that the roof is a flat roof, or is there a setting to tell the software that there is an internal ceiling between the rooms and the exposed roof. I watched your learning video and it doesn't say anything.
Hi Shane, I am have completed my model and now it has lost all the room data and my simulation cannot be done, even though the building is shown in isometric and other views. When the file initially opens it shows the room data, and then deletes it. Why? I have sent you a reply with a file attachment by email, I very much hope that you can resolve this? This is not the first time it has happened this week.
Hi Sean, that is very unusual. what exactly preceded this? Was there a crash or error perhaps? I will indeed most likely need to see the project in question however if you replied to the notification email from Communities I will not receive this. Could you please upload this to this link.
(Note we will need the entire Workset folder as shown here).
Shane Regan | Principle Building Performance Support EngineerHevacomp to OpenBuildings - A complete guide for every user | Bentley Communities
Hi Shane,
I have uploaded the complete folder as requested. Hope you have got all that you required. If not let me know.
No nothing unusual happened before the data was lost. I saved the .dgn file as normal, and as I have been doing all along. It was after the save that the room data disappeared. Not only the has it .dgn lost the room data it has also lost all the design parameters , and this is what happened earlier in the week, and I started afresh.
Hi Sean,
I have received the files successfully, thanks. I have reproduced what you describe and I have referred this to our developers so that they can look at the underlying code. I will let you know as soon as I have any feedback.
If this is a recurring issue then it perhaps may be related to how you are creating projects - are you making sure to create a new Workset for each project, as below?
Absolutely following the guidance to the letter. First creating a WorkSpace, then the WorkSet and then creating a New File.
The WorkSpace is saved in C:\ProgramData\Bentley\OpenBuildings CONNECT Edition\Configuration\WorkSpaces on my desktop. The WorkSet and New File are saved to a central server and not on on my desktop. But I have been saving all day without any issue until the last save when the problem occured.
