When I 'setup' roofs I'm getting an error of "Object reference not set to an instance of an object" and it causes parts of room surfaces to be removed from my project tree and not associated with any floors, yet they can still be seen in the views.
Below is a screenshot after I've 'Hide all floors' and it's still showing these un-associated surfaces which are then causing more errors as essentially it's removing random walls and floors from the project tree.
Are you able to help me re-associate these surfaces please?
Ok great thanks Shane,
Have you found out how to resolve the un-associated surfaces that got deleted from the project tree at all?
You are very welcome Adon.
Was this in relation to the other matter from Service Request 7001220989?
Shane Regan | Principle Building Performance Support EngineerHevacomp to OpenBuildings - A complete guide for every user | Bentley Communities
Yes part of that aswell but it occurred in the files I sent over for this post when I added the roof. the screenshots are in my original comment on this post.
Thanks for clarifying, I see what you mean. I have logged a defect for this matter so that our developers can view the underlying code. However this appears to just be a visual issue so for now the existing room data itself should be fine to proceed with and to run your calculations.
