We require the xml file from the Part L calculation to enable us to provide an EPC however the following error appears when we run the SBEM with level 4 complexity selected.
The program will run when level 3 is selected
Our assessor is trained to level 4
Shane
We have completed the calculation for Sandygate Hall & the REEL Cinema however when we upload the xml we receive the following error logs.
Steve
Hello Steve,
Please check that your Insurance date settings are correct, and that your PI Limit is correct, prior to generating the XML:
Shane Regan | Principle Building Performance Support EngineerHevacomp to OpenBuildings - A complete guide for every user | Bentley Communities
Answer Verified By: Steve Austin
