Hi All
Can someone please explain the folder structure for OpenBuildings please; we use / used Hevacomp so will be using OpenBuildings for energy simulation primarily.
The structure seems to a simple mechancial engineer complex. How do you use it ? Where are you supposed to create the folders initially ?
Any help gratefully received.
Cheers Graham
Hi Graham,
Hope you are well. Simply put, I would consider the structure as consisting of these three parts:
The process I would recommend to create a new project can be found here.
Should you wish to save Worksets/Workspaces in custom locations, eg a shared server, you can do so as shown here.
Shane Regan | Principle Building Performance Support EngineerHevacomp to OpenBuildings - A complete guide for every user | Bentley Communities
Thank you Shane very useful. If I get confused again I'll be back in touch.
No problem Graham! Absolutely, if you need anything just let us know.
