Copy floor not working. When we copy the floor we get given the error above. Any suggestions.
Hi Hrushik,
I would need to see the project to say for certain - could you please forward the Workset folder (as shown here) to this link.
Shane Regan | Principle Building Performance Support EngineerHevacomp to OpenBuildings - A complete guide for every user | Bentley Communities
Hi Shane
I have sent the Workset Folder. There are two versions of the project and V3 is the errored project. It mentions that the 2nd floor has indeed been copied as the third floor but this floor is not visible.
Thanks Hrushik, will take a look now.
I can see what you mean. However I deleted the floor in question via the project tree, and successfully copied the 2nd floor (up 2.3m - was this correct?) and the model is now working fine. This was on Update 8, Are you perhaps running on the older version of the software (to find version see here)?
Answer Verified By: Hrushik Tadvai
Thanks, I am currently on Update 7 which might be the issue
