Copy floor not working. When we copy the floor we get given the error above. Any suggestions.
Great, that should explain it, as there were several fixes in Update 8. If the problem persists after updating please let me know and I can send you the working model.
Shane Regan | Principle Building Performance Support EngineerHevacomp to OpenBuildings - A complete guide for every user | Bentley Communities
Hi Shane,
I'm having a similar issue as Hrushik except the floor builds but it leaves behind a seemingly disassociated floor when I "hide all floors" (See picture below). This then seems to be causing the error Hrushik mentioned above when I attempt to copy another floor in after (In total I need 8 floors).
I'm using version 10.08.00.44 and it's still occurring. Are you able to provide a solution at all please?
Hi Adon,
Sure, I will need to see the Workset for the project firstly - to avoid this matter overlapping with Hrushik's issue I will log a Service Request now and will send you a link to upload shortly.
ok great thanks.
