Hi Shane - I have not used OpenBuildings since we last spoke but I am still getting the same error when importing a project from Hevacomp. Can you help please?
Steve
Hi Steve,
I suspect this may be an install issue but could you firstly forward this particular Hevacomp project so I can ensure all is in order with it - please upload to https://bentley.sharefile.com/r-r9fe100b8f01f4d31bf7ea7f9b4d27eb1
Shane Regan | Principle Building Performance Support Engineer
Thanks Steve,
Can confirm that the project imports perfectly into the latest version of OpenBuildings, Update 8.
I would recommend uninstalling OpenBuildings Designer from this machine and install as shown here.
Beforehand it would be advisable to:
When installing please ensure to select configure and select the NM dataset.
Shane
