How do I create an external door with glazing as you could do in Hevacomp ? Have read through various files on here but can't find an answer ...... am I missing something ?
Graham
First of all which version are you using?
Which datasets have you installed as there may be one readily available within the Place Door menu
You could create your own one using Frame Builder
Or you could import one rom a RFA file
Ian
currently using OBD 10.10.01.151
Hi Ian
I'm using energy simulator not the drawing packages so it's for calculating heat losses / gains, etc. The version I'm using is the latest update 8.
Cheers
Then this is something that somebody with more specific knowledge of OB Energy Simulator needs to answer
Thanks Ian, that's exactly what I think. Nornally I get a response so I'll sit tight and wait ..... Cheers anyway.
Hi Graham,
Sorry for the slight delay, only seen this now. This is something I actually logged an enhancement request for - so that the workflow is made more akin to that you mention from Hevacomp. At the moment, the glazed area needs to be entered as a normal window.
Shane Regan | Principle Building Performance Support Engineer
