Trying to create an EPC/SBEM certificate however an error pops up saying "At least 1 Zone needed." Version v10.15.1.23
For the Part L calc, there are 3 zones which I've used and for each one a different HVAC system. I've created inputs for each one and when I've tried to run the EPC/results/compliance it comes up with the error message attached.
Throughout all this I have not encountered any error messages in notifications.
I've recreated the model in the same workplace however in a separate workset and the same error message displays.
Not sure what I've done wrong. How can I resolve this?
Hi Amrit,
Glad that helped. It is likely such rooms belong to multiple zones (eg they will also be in the "All Rooms" zone, for instance) and you may also have included these other zones as a HVAC Zone - this may be why you have to specify individually.
I will send you a request shortly to obtain the project from you so we can be certain.
Shane Regan | Principle Building Performance Support Engineer
Hi Shane,
I wonder why the software creates "all Room" zone and "Each floor" zone because this lead me to specify each room to my own create zones individually. doing so is very time-consuming.
Could you please advice if there is any way to avoid creating "All room" zone and "each Floor" zone please?
Kind regards,
Bake
Hi Bake,
Shane is on leave for this week and I thought of filling in.
You definitely do not need to use or assign the "all room" or "each floor" zone if that is hampering your workflow, it is there as a default so that it becomes convenient for users if they wanted to assign HVAC systems to the entire building or to individual floors. You can create your own zone and work with that.
Krishnendu
Thank you. I am not sure if I explain the issue clearly, is there any chance we can have team meeting so that I can excerise and show it to you
Many thanks
No worries,
I will be creating a new service ticket and setup a meeting with you.
