Hi there,
I have tried and run through the recommendation for generating EPC. However, I am still failing it to generate one, Can you help please?
Hi Shane,
I look forward to hearing from you soon and Happy New Year.
Kind regards,
Many thanks Maitiniyazi, a happy new year to you too.
I have been testing your project and can see little wrong here - after selecting EPC England the EPC is showing fine - see below:
Are you ensuring to select All Rooms prior to running the calculation?
(Also, as an aside - I see you have created several roofs - please note this is not required for flat roofs as the software creates these for you automatically).
Shane Regan | Principle Building Performance Support Engineer
To add to the above - I think the issue may be that you are running on an old version. Could you please check your version as shown below, and reply with a screenshot?
Finding your OpenBuildings Energy Simulator version number - OpenBuildings | AECOsim | Speedikon Wiki - OpenBuildings | AECOsim | Speedikon - Bentley Communities
Answer Verified By: Shane Regan
Thank you for your both answers and I am now installing Update 8 version, see if works
Answer Verified By: Maitiniyazi Bake
