Since I been using update 8 version, there are different colors representing walls (Blue shows exposed wall, which is right). However, the model also has orange color wall showing partition (that is supposed to be exposed wall), I wonder why?
as the attached shows, could you tell me how I can solve it please? annd this problems increases when i coppy the floor.
Many thanks
Hi Bake,
Good morning. I'm not too sure how this might have occurred- was there anything strange that preceded this? In any case, if you right click on the Partition in the project tree, select properties, you will be able to change the surface type to exposed wall there.
Shane Regan | Principle Building Performance Support EngineerHevacomp to OpenBuildings - A complete guide for every user | Bentley Communities
Hi Shane,
Good Morning, that solution (select properties, you will be able to change the surface type to exposed wall there) would work but time consuming when you have hundreds of wall to be fixed.
I still wonder why it happends such a problems though.
Walls will remain external and only be changed to partition if there is another room nearby, within the distance set in your Adjacent Tolerance setting below:
Adjacent Tolerance setting - OpenBuildings | AECOsim | Speedikon Wiki - OpenBuildings | AECOsim | Speedikon - Bentley Communities
So it would be worth checking that setting firstly. If you wished us to investigate this further we would need you to forward your project - if you wish to please let me know and I can send you an upload link.
Answer Verified By: Shane Regan
