CIBSE Heat Gain - Error
Good afternoon,
On my CIBSE heat gain calculations I'm getting an error against most of the rooms for the Sensible gain. When I dig into the calculation it's because the mean sol-air temperature is not being calculated correctly and returns a value of NaN as per the third image below. Do you have any ideas as to why this is? I have followed the video tutorials up until now but with my own model so I'm not sure what the issue could be.
Many thanks
