I been trying to do heat loss but the roof light was't incldued in my heat loss calcuation, rooflight isn't corresponding to the roof as attached show, could you help please?
Hi Bake,
Good afternoon. We would most likely need to see the project to confirm what is happening here - could you please log a Service Request and we would be happy to investigate?
Many thanks,
Shane
Shane Regan | Principle Building Performance Support Engineer
I think I got it working now. if I may ask, I got numbers of Exposed wall attached to the Ground (Basement Level), is there any quicker way to do globally change the heatflow to the ground please?
Good morning, glad to hear that is now working. So just to clarify - you are looking to change the surface properties of the exposed walls in the basement level to a ground floor construction?
Good Afternoon, I am looking to change the heatflow type to the Ground (the exposed walls in the basement level to exposed to the ground)?
Hi, thanks for clarifying, I see what you mean, as this setting can only be changed individually for specific surfaces. I can see this may be time consuming so I will log this with our development team so that they can assess bringing this option into the Global menu. Many thanks for the feedback.
