Part L Calculation
Shane
I have a rogue U Value of 0.43 for the external walls on the Part L output document, none of the walls have this U Value and I cannot see where it is calculated from.
Do you have any ideas as to what this could be or could you have look at the model to see if you can see where it is from.
