Hi there,
is that possible to change the existing room height (especially on the midle floor rooms) on energy simulator rather than redraw it?
Hi Maitiniyazi,
The ability to alter existing room height has been logged with development, and I will add your request to raise the priority of this. The only way of changing a rooms height at present would be to merge the room with one above.
Shane Regan | Principle Building Performance Support EngineerHevacomp to OpenBuildings - A complete guide for every user | Bentley Communities
Thank you and I hope it can be sorted ASAP becasue I been finding this software difficult and time-consuming to complete even a simple model. And this is heavily affecting our project progress.
Thank you!
I can confirm that I have logged this accordingly for you and it is now being assessed by product development. On another note, update 9 will be released shortly, which should assist with other issues as it includes many fixes and some new workflows according to user feedback.
Thank you so much
We are also having the same issue. This is heavily affecting our work progress even with the small scale projects. I can see that this issue has been raised in January 2022 and it is now December 2022 so an entire year has gone past and yet nothing has been updated.
