Hi I have model the building with 75 rooms and warm floor as heating type. the result only shows the plant ratio of 1 and pre-heat period of 0. However, I am look at different plant ratios and pre-heat period hours.
Thank you!
Hi Maitiniyaze,
I have tested this here and all appears to be working fine - the below Pre-heat and Plant Ratio results are shown automatically :
What version of OpenBuildings are you running? (You can find as shown here).
Shane Regan | Principle Building Performance Support Engineer
I am using Update 9 now?
some projects, i could see Plant ratio resutls on the Heat Loss report.
Hi Maitiniyazi,
This feature will always be enabled in results by default, if it is applicable to the rooms that are being calculated.
The pre-heat times displayed are based on the occupancy schedules selected for your room - eg if your rooms are set to be occupied for 24 hours a day then there will be no possibility to preheat prior to occupancy.
Taking one room for example:
24 hour - no preheat possible:
Office (Occupied from 8am) - preheat shown until then:
Answer Verified By: Maitiniyazi Bake
Thank you, it works now!
Great to hear! If you need anything else just get in touch.
