I am running a CIBSE Heat Gain calculation in OpenBuilding Designer and have recieved the following error:
"index was outside the bounds of the array openbuilding"
Thanks Grant, will get back to you soon.
Shane Regan | Principle Building Performance Support EngineerHevacomp to OpenBuildings - A complete guide for every user | Bentley Communities
Hi Grant,
I have been inspecting the project here however all appears to be working fine - eg please see CIBSE Gain as below:
Would you mind please replying with a screenshot of the error you are encountering?
Also, could you please check what version of the software you are running?
Finding your OpenBuildings Energy Simulator version number - OpenBuildings | AECOsim | Speedikon Wiki - OpenBuildings | AECOsim | Speedikon - Bentley Communities
Hi Shane,
The steady state calcualtions run for the first instance, when I close the window and try to run them again I run into the below error:
Thanks Grant, looking into this now.
