I need help with placing a window in a wall that doesn't touch the floor level.
All the pink figure in the following picture is one room obtained by merging several rooms from different levels.
When level 1 is active, the window probably is not placed because the wall originally comes from level 2.
When level 2 is active, the window probably is not placed because the chosen room is from different level (1).
Tried all possible still heights.
How can I place it in this situation?
Thank you,
Rotari Dan
Hi Dan,
Thanks for raising this query, could you please log a service request so that we can take your project and test the scenario? Please submit a service request here.
Krishnendu
I submited a service request
Thanks Dan,
Please note I picked this up a while ago and sent an email to the "design@......" email address that you logged the Service Request under.
Shane Regan | Principle Building Performance Support EngineerHevacomp to OpenBuildings - A complete guide for every user | Bentley Communities
