Hello
When running the Part L, EPC calculation i'm getting a error message that the C-Reg-Number is not valid.
can you please advise.
thanks
Keith
Hi Keith,
This is referring to your Assessor details as below:
You may need to check the correct details have been entered there, and if so just double check all is in order on your accreditation schemes records of same.
Alternatively please note you can just leave this blank to generate the EPC.
Shane
Shane Regan | Principle Building Performance Support Engineer
Answer Verified By: Shane Regan
Hi Shane
I hope that you are well.
The assessor number is the same as the CIBSE Certification Lodgement system?
I will need the assessor details to be able to lodge an EPC.
I'm well thanks, hope all's good with you too.
I'll dig into this for you - I am logging a Service Request now and will send you a project upload link.
