Hi
I have the following problems with my Part L 2013 which I don't seem to be able to rectify. Under Criterion 2 the Wall element is shown failing, it's Partition 8 (which is wrong in itself) - I've been through each room on screen and the paper printouts but can find no error.
Anyone got any ideas or is my program just corrupt ?
Cheers
Hi Graham, nothing wrong with the program - under certain conditions partitions are taken into account as part of the SBEM check for criterion 2. Please find info here:
BRUKL Report - Internal Surfaces in U-Value check - OpenBuildings | AECOsim | Speedikon Wiki - OpenBuildings | AECOsim | Speedikon - Bentley Communities
Shane Regan | Principle Building Performance Support EngineerHevacomp to OpenBuildings - A complete guide for every user | Bentley Communities
Thanks Shane
I thought I'd gone through all this and checked it as per the article you refer too but obviously I've missed something. I'll go back and check again
Cheers G
No worries at all Graham, it can be a tricky one to narrow down!
I can have a look too if you need? I can log a Service Request and get the project from you if you like?
Actually that would be helpful, I've actual had other problems with this file but slowly over a number of days they've rectified themselves apart from this one issue.
For any other users who may be experiencing similar, in this particular instance SBEM flagged these partitions as they were adjacent to unconditioned rooms - i.e. rooms that had the HVAC System Type in PartL set to "No Heating or Cooling".
They were no longer flagged upon either improving the U-value of these surfaces, or adding HVAC to the unconditioned rooms.
