How to disable the "Unified File Naming Utility"
James
James,
Could you please paste a screengrab of the scenario, that would help us understand the scenario a lot better.
Krishnendu
Hello James,
Are you talking about the file naming utility that pops up when creating a new file via the Building Templates UK?
If yes then this has been specified in the BuildingTemplate_UK.cfg file. Commenting out BB_NAMING_STANDARDS_ENABLE will help you get rid of the naming utility.
Hope this helps you.
many thanks as usual Alifur
It is workingThanks
Always happy to help.
Regards,Alifur
